nicksavage
- Dec 3, 2019
- 1
- 2
Hello and thank you for anyone that reads this.
I have a John Deere x324 with a kawasaki fh661 engine.
I am in no way a true mechanic but have did most work on my own equipment for 50 years.
My question is when I go to adjust my valves I hold the nut as always while turning the outer nut a little to loosen it. Then I adjust the inner nut and get my clearance. Now when I do that and hold the inner nut tight to tighten the outer nut and then recheck I have no clearance. I know the inner nut is not moving because I have did this a dozen times on this mower and even video taped it to see if it even moved slightly, which it does not.
Can anyone help me to figure out what I am doing wrong. Thank you.
