Transmission(s) Oil Filter OEM Crossover
bartles
I am working on a Zero Turn Model 5900709. According to my parts reference the OEM filter part number is 5101026X1. I checked with Fram
for their cross over part number. They advised they have no filter that matches Snappers requirement.
Anyone out there with some advice and help? Thanks in advance.
bartles
My lord it is a Hydro Gear 52114 filter. Stens has it under PN 120-738. A&I has it under PN A-B1OF52114. Also it comes as a CARQUEST 94102.
Here is some the oems that uses the same filter.
A few more
John Deere MIU13018
WIX WL10102
Rotary 12374
MParr
I’m not sure that FRAM even makes a filter for this application.
DO NOT try to fit a regular oil filter to your hydros. The hydro filters DO NOT have an anti-drain back valve. And, the burst pressure is different.
A Hydro-Gear 52114 will work.
Stens 120-738
Rotary 12374
NAPA 400102
bartles
A few more
John Deere MIU13018
WIX WL10102
Rotary 12374
A few more
John Deere MIU13018
WIX WL10102
Rotary 12374
Thanks!
Fram? Really?? I wouldn't use a Fram even if they were giving them away for free.
MParr
I’m not sure FRAM even makes a filter that crosses to a HG52114. I’ve looked and can’t seem to find one. I wouldn’t be surprised that they might make something under contract for Hydro-Gear, Stens, Rotary, or manufacturer’s branded filters. Hydro-Gear doesn’t make their filters. The Hydro-Gear filters look like they are made by WIX. However, they have the option to change their suppliers.
