Transmission fluid
jsirmg
What type of gear oil do you put in a RS800CVT?
None as it is not gear oil.
tom3
I think it uses the 00 weight grease, drill a hole to put it in. Some videos on you tube on how to clean the pulleys too, very important maintenance there.
jsirmg
Thank you, I checked and Tractor Supply sells it for $5.29. Appreciate your help.
You don't have drill a hole. There place to put it in per GTI. Just email GTI and they can send a picture of where to add the grease.
But thanks for the correct grease as I though it was EP2.
Convert
If you need a good place for "00" grease try Tractor Supply.
Cost me $5.00 for a quart.
Look in the farm eq. section not the Auto Truck grease section
Convert
Tom B
jsirmg
Thanks, Tractor Supply has a great inventory of in stock tractor parts.
