TRANSMISSION FAN
OLIVER1955
Hello, I have recently purchased at auction a 2012 G23 mower with high tipping, on giving it a full service before using it I noticed that the transmission fan, which is plastic/nylon was broken, and clearly had been broken for some time as there was an irregular shaped hole in the middle of the fan remains, has anyone had this happen before?? Any tips on dismantling to fit a new fan, there doesn't seem to be an obvious way to take it apart, if you undo the fastening bolt on the shaft it will push back but not enough to clear the splines, also, does anyone know a source of purchasing a new fan, I can't seem to find any online. Any ideas would be welcome. The mower operates smoothly but I'm concerned giving it much use will cause overheating of the transmission.
