I just installed a Husqvarna repair kit for the transaxle mounts, along with a low hours K46 transaxle. I changed the fluid before installing it. I also replaced the drive belt since it was the original one. When I started the mower, it wouldn't move in either forward or reverse. I checked the drive belt for proper routing, which was correct. I made sure that the transaxle was in the drive mode, which it was. I tried it again, and it moved in reverse, but barely. The same for forward. I tried several times, with each time getting a little better.
Is this just an issue with bleeding the air, or something else?
Thanks ?
Thanks ?
