Where is the drain plug on the transaxle on a model 917271022 ?
Ron Hanson Forum Newbie Joined Sep 22, 2021 Threads 1 Messages 1 Sep 22, 2021 / Transaxle fluid change #1 Where is the drain plug on the transaxle on a model 917271022 ?
H hlw49 Lawn Addict Joined Jul 11, 2021 Threads 36 Messages 1,392 Sep 22, 2021 / Transaxle fluid change #2 It has no drain it says to drain it through the breather port. To do that you would have to remove the hydro from the mower. Or if you had some kind of syphon you could syphon it out through the breather port and fill it there as well.
