Hi all. Ran over a good sized rock (accidentally) today, mower and engine of tractor stopped abruptly. Checked both blades and replaced one that looked a little bent. mandrels turned ok and belts looked ok. But when I start the engine then try to engage the mowers, the engine dies.
Tractor is Sears Craftsman 42 in. deck. 4 years old. I use mulching blades and change them each year. The deck was at it's full height when the rock appeared.
Trying to figure out why the engine dies when the mowers are engaged.
Thanks.
Thanks.
