Toro
motime
I'm thinking about buying a Toro 54" Timecutter from Tractor Supply. Does anyone know if they are built cheaper for TS as I've learned that JD is for say Lowe's? Also, I've never used a o turn and looking online, it said not to mow over more than a 15 degree slope. I've been using my old JD145 to mow parallel along an approximate 25-30 degree slope. Thanks for any input.
All Toros are built to the same quality no matter where they are sold. I recommend that you go to your local Toro dealer, as most will honor the big box prices. On top of that they make sure that the unit is set up properly.
motime
Thanks
