I came across a 50'' deck Toro with Myride at Home Depot 2 days ago.
I am considering going back to ZTR and here's my question:
I have total crapfor grading in my 5 acres to mow. Small hills, bumps, what not. Ride is VERY uncomfortable and painstaking, as I have to creep through the property slowly.
Currently, I am doing main mow with UTV, towing a flail mower behind. UTV is most comfortable vs riding mower and two ZTRs I had before. But flail cut quality is meh...
So here's my question. Is that Myride a gimmick or it really works? As, otherwise, Toro does not have good rep, looks cheaply made and seat itself is not really that comfortable. Also, it has standard bolted frame and I KNOW it will start bending and cracking on my terrain. I don't want to invest into something that I will have to rid off because it starts falling apart or killing my back.
I can get Cub Cadet with floating front suspension, more comfortable seat, unitube frame and larger deck for same money as 54'' Toro. Ultima series. Have no rational explanation, but that frame looks solid.
Anyhow. Is that Myride worth the money?
Thank you
Thank you
