Model: 74325
Serial: 250002187
I've had this machine for 15 years now. It came with a set of high lift blades. I've replaced them once and remember having a really hard time finding them. The blades on the parts list are medium. This time around, I'm having an even harder time but managed to find a set that I think might work but they are a little different. The originals were just flat stock and utilized a blade stiffener. The new ones are stamped in a way that appears to provide stiffness. If I continue to use the stiffener, it will only be making contact with the outer edges because of the rolled edges of the new blade. Do I eliminate the stiffener? My other concern is the bolts bottoming out on me. These mount with one bolt through a round hole in the blade. No star mount or anything like that.
Serial: 250002187
