Have a couple month old Toro Titan with my ride seat. Unit has quit a couple times and suspected the seat switch. When I looked at it I found the connector had fallen off. It was fairly hard to get to the switch without taking the seat but I didn't see any obvious damage to the connector housing on the wiring harness. I was able to put the connector back on the switch well enough that the mower operates but it did not latch. In talking to the dealer they said they had seen issues with the latch before but I didn't get any more detail on that. I had considered taking the seat off the suspension frame as it looked like there were only 4 bolts that were easy to get to but I found a forum post stating that there were two additional under the seat that are much harder to get to.
The dealer is going to fix this but would like to understand the issue. Are connector issues like this a common problem?
