Toro Timemaster engine and spring ID
Cuttinuplc
I have a Toro timemaster 30" from this year 2021. The 10hp 223 OHV Briggs has no identification on it other than the model and serial on this sticker. This model number turns up no results for me online.
I need the carb spring closest to the center of the engine. I believe that's the choke return? I would love if someone could give me both spring model numbers and the engine model number if the one on this sticker is not it (14D93)
Thank you
Need pictures of the carb spring area and engine numbers to look it up.
It going to be a little hard if the spring is missing.
Sorry I made a mistake. You are correct as usual. I edited my poor info just now.
If it is a 2021 model, the model number for the unit is 21199. This model uses Briggs engine model number 121S020130F1. I’m thinking you need the choke return spring, part number 799179.
Another one with the same choke spring missing?
