Paulc70beach
- Mar 24, 2020
- 1
- 4
Mower last serviced probably in the fall, left to sit until Wed. Wont start, dead battery wont charge. Install new battery mower starts almost immediately, able to run it perhaps 5 min, tested PTO and belts, blades are spinning. Engine begins to struggle, disengage PTO, engine recovers, engage PTO engine falters. Leave pto off, engine continues to struggle, move throttle to choke and engine runs strong, falters as soon as I take it out of choke, move back to choke engine runs fine for a time then dies. Able to restart it 3 or 4 times, cant move throttle out of choke or engine dies, eventually it simply refuses to start. Fuel is new, filter both air and fuel are new...battery brand new.
Thoughts? I know next to nothing about engines. Was able to remove air filter and open carburetor. Looked "fine", no obvious gunk or grime, clean and shiny. Choke "door" moves a lot with throttle control. Inner "door"(don't know what to call it) moves very, very little throughout throttle lever travel.
Thanks, Paul
Thanks, Paul
