Toro time cutter ss5000
cfoster47
Mower isn’t starting I’ve replaced the seat switch and solenoid and also have a new battery. Every time I turn the key it just clicks once.
Can you turn the engine 2 full revolutions by hand ?
Scrubcadet10
Moderator
Staff member
You should be able to rotate via the screen on top of the engine.. Or if it's a manual blade engage (you push a LEVER/HANDLE) grab the the pulley shaft under the mower.
Remove spark plug wire if you do this
cfoster47
Ok I’ll give it a try when I get home this evening thanks
cfoster47
Dove in a little deeper and found the plug for the switch on the handle was off.
