Need to look at the lift system. works like a hinge. and pins. Something isn't align right, or something is jammed. Pretty basic system. Keep looking and you'll figure it out;
Have you released the transport lock ?
On the height adjuster there should be clip of some sort to stop the height adjustment lever bouncing out when trailering the mower.
