Toro SR4 Self Propelled
steveleb
There is a squeaky noise when push down on the handle to engage the self propelled. It does not engage like I was manually cutting the grass.
Post the units model and serial numbers. I’m guessing your drive belt is bad.
steveleb
20095 21in Personal Pace. After I experienced the problem last week I started looking at it that afternoon. Just flipped it over to see if anything was broken nothing that I could see. started it up on the driveway and away it went with no problem. Just finished cutting the back yard with no problems. Unfortunately I tried to cut a section of grass that was a little high by the driveway and it stopped wheels not moving.
