Toro problem
axleridge
Hi new to your group
I have a toro with a Kohler command pro cv75 Z master with Delphi injection system.it will no run it has no spark & no injection pluse ( has power to injector).replaced speed sensor checked all safety switches all power & earths at ecu.All fuses have Powerade wiring test & ok.1 thing I've noticed that with ignition switch on the mil light does not illuminate and if I bridge test plug no flashes appear. If it was a car I would say ecu
Anyone had this issue before.Note I have disconnected all sensors bar speed sensor and cranked over still no pulse from ecu
Cheers
