Toro MX4250 zero turn with Loncin 708 v-twin engine cranking slow
dtestin
  • / Toro MX4250 zero turn with Loncin 708 v-twin engine cranking slow
It cranks great with plugs out. Battery is good. Seems like ACR automatic compression release is not working. Luckily it starts easily once I hold the key and get past initial compression. Any experience with this or knowledge of the ACR mechanism? I adjusted valves and did not see a "bump" on exhaust valve. Also checked electrical connections.
I have yet to see an ACR failure on a Loncin engine, but this could be the first. What did you set the valve clearance at? Can you give us your engine model numbers and I’ll see if I can find a service manual for you. This manual is probably not for you engine, but will show you where the numbers are located. https://www.toro.com/getpub/70680
dtestin
Model 74760, I believe it is Engine: LC2P77F
Clearance (cold) (Intake) 0.004 - 0.006 in.
(0.10- 0.15 mm)
Clearance (cold) (Exhaust) 0.006 - 0.008 in.
(0.15 - 0.20 mm)
dtestin
Do you have a picture of the ACR so I can see how it works?
Here is a service manual for that engine. I would start by double clicking the value clearance first, as you may have set it on the intake stroke,not the compression stroke. https://www.toro.com/getpub/117255
On 4 strokes as Rivets is getting at, there are 2 TDC strokes you can pick from.
dtestin
Valve clearances are set according to specs on compression stroke. Mower runs great but just have trouble getting it to crank. It can just barely overcome the compression if I hold the key for several seconds. Other ideas?
Check you battery voltage while trying to start the engine. You may have a battery which is getting weak, voltage is dropping below 10 VDC, or a bad ground connection.
