Toro belt replacement assistance
WISC
I have a Toro model 74467.
Belt part # is 135-1873. Belt is not in stock at local store.
What I really need to know is the dimensions so I can try and find a replacement belt. The specifications are not listed, even jacks small engine didn't have the dimensions. Does anyone know the dimensions so I can try and find an after market belt?
mechanic mark
Use OEM Toro parts, shop for best price, it will last longer, exact fit no problems.
Talked to Josh said you would have belt in 1 week, best price I could find.
Belt size is 5/8” X 189”. As a Toro guy and been doing this for a couple years I would not recommend replacing with a non-OEM belt. You could easily spend big bucks for a belt that doesn’t last long.
