I have a toro 21 super recycler, 1 year or so old. It has a B&S engine. There is a tube that runs from the engine to the air intake just below the filter that seems to recycle engine gasses. I notice that when the tube is connected the engine slows down. When I remove the tube the engine speeds up and runs better. My tube also seems to spew a decent amount of blue smoke and there is some oil. Surely this is not the intended design. Can anyone shed some light on what should be happening here? Surely there shouldn't be oil going into my carb with these return gases? I am running it disconnected for the time being. Mower runs better like this. My son uses this mower to mow multiple lawns a week. Also - who put that overflow on the gas tank that spills into the air filter housing. That is dumb. thanks in advance.
