Handcannon
- Apr 18, 2021
- 2
- 7
Put new carb on mower this spring. Starts first pull but dies when trying to mow. Thanks
Model 20016. Yes it came from Amazon. Don’t seem to have any obstruction from fuel tank to carb. Jets are clear.What's the model number of the engine? usually stamped above the spark plug into the sheet metal or above the muffler.
it could be an issue with the carburetor you bought, if it was a cheap one from EBay or Amazon. do you have good fuel flow from the Tank to carburetor?
Adjust the one screw that you see between the air filter & the mounted carb. Like I mentioned, keep it running by pumping the bulb once every time it starts to die. I probably had to do that 15 times before it kept running by itself. You can remove the filter to adjust the carb.what carb adjustment did you do?
