logert gogert
- Jan 11, 2020
- 16
- 546
alright guys, so you have probably seen my other threads about this same mower, first i found it on side of road, the i brought it home, cleaned the carb, then it ran like a jewel for about 2 months, i don't even know why he threw it away, 5 speed tranny was smooth, engine ran like new, added with a new blade that thing cuts through tall grass like butter, and actually, i think it would give any 16hp+ engine a run for its money when cutting.
but about a week ago i was cutting somebody yard, and out of no where, it started to act all wonky, it was as if i were cutting, and i were to turn the ignition switch off, and right before the engine dies you switch the ignition back to "on", and it did that for about 10 seconds then it died.
i finished his yard with the push mower, brought it back home so i could take a look at it, i made sure everything was in neutral, ignition on, throttle on, tried to start it, wouldn't start, i pulled the plug, it looked fine, wasn't flooded or anything, i checked for spark, it had spark.
as you guys know i don't have a compression checker so i couldn't check for that......
i suspected it was a carb issue, but when i put a wee bit of gas in the throat of the carb, it wouldn't even try to run that way, not even with starting fluid.
what do you guys think the issue is?
model numbers:
_____________________________________________
on engine:
model: 286707
type: 4029-01
code: 960607ZB
on frame:
model: 5655
serial: 3001943
model numbers:
on engine:
model: 286707
type: 4029-01
code: 960607ZB
on frame:
model: 5655
serial: 3001943
