Toro 22178 hard to pull start
elton
Picked up a older toro with the kawi fj180v looks to be in great shape overall i paid $30 as is .... checked all the simple stuff the fly wheel was a little rusty cleaned that up pulled the plug no change pulled the blade cover only thing i see is the top belt is a little tight my problem is it doesn't turn over smooth there's some sort of drag
elton
After more digging the drive belt jumped off the pulley that sloved the hard to pull issue but now there's bigger problem
BlazNT
AND... we are on pins and needles. Let us know.
elton
Pretty sure the flywheel key sheard i can spin it easily i stuck my finger over the spark plug hole nothing calling the shop Monday i have no way to get the flywheel off
BlazNT
All you need it a wrench big enough for the bolt a pry bar and hammer. Easy.
elton
Ya I tired with a 1/2 gun im not sure if it's reverse thread or not
It is a std right hand thread.
Remove the spark plug, and fill the cylinder with some soft woven rope.
Turn the nut slowly to compress the rope then try again with the rattle gun.
If it has never been off it will fight you to the death.
elton
Ahh ok I'll give that a whirl hopefully thats the issue it's a nice mower
elton
Update i backed off the valve adjusters then tapped them a little and readjusted them runs great now just need a few parts..... Dunno how to add a picture lol
elton
Well its been a fantastic machine so far starts first pull runs awesome im in it about $60 now IMG_20180501_125046.jpg
