i have been fighting my butt off with a new tire for an hour now. they must press them flat when they are made because for the life of me i cant get it to seal on the bead.
i even used a 2" ratchet strap to pull the tire in but its tight against the rim all the way around and the bead still wont seal so i put a tube in it.
why do i need to put a tube in a brand new tire?
getting old tires back on the rim is easy to do with a ratchet strap but not with brand new tires
if i have to put a tube in a brand new tire then whats the point of even buying a new tire, i can put a tube in those dry rot cracked tires if thats the case
i can be the only one who is feeling this way
