Tire change
Biggles
Can I change the size to a 10-8 or 8-8 instead of the 9.00-8 since they are doing away with it and if so which would you recommend me going too.
Logan, He explain that if you fully read the post. The tire manufactures are dropping the production of the 9 inch wide tire.
If you referring to the 20x9-8 tire that came on the mower then yes can go narrower or wider. Just going wider make you have enough side clearance between the tire and the frame. Also some decks can rub on the wider tires.
Biggles
Ok I’d like to go wider then appreciate the comments
