Wheel Horse Guy
- Dec 14, 2014
- 3
- 11
I was not at home and my son was doing the trimming when he said the engine started racing then the rpm's went way down and it was barely running so he stopped it. Near as I can tell a spring/springs got caught on one of the branches of a bush. After searching the bushes and using a metal detector we could not find a thing. There is one small spring that is still connected to a rod that runs from the butterfly, and I believe, to the governor. How do I find out what spring/springs I need and where they go? This is a Bolens/Troy-Bilt with a Briggs and Stratton 500 Series 5.00 there is a barcode on the engine, 0710265191029. The mower is model 11A-74E065 183617 serial # 1L037K20372. Any ideas? Thanks, Robert.
