my 1994 lawn boy 10515 spark plug threads are stripped out. is this the end?
E earnest t bass Active Member Joined Feb 26, 2020 Threads 16 Messages 54 Apr 16, 2022 / threads stripped #1 my 1994 lawn boy 10515 spark plug threads are stripped out. is this the end?
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 55 Messages 14,683 Apr 16, 2022 / threads stripped #2 Short answer, NO. I’ve put many spark plug HeliCoils into these engines without tearing them down. Any good repair shop should be able to do this for you.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 64 Messages 24,647 Apr 16, 2022 / threads stripped #3 $30 for a helicoil $ 40 for a solid insert ( Aust $ ) . Any engine if I have clean access to the plug hole I do them in around an hour .
E earnest t bass Active Member Joined Feb 26, 2020 Threads 16 Messages 54 Apr 16, 2022 / threads stripped #4 thank you
sgkent Lawn Addict Joined Sep 27, 2017 Threads 30 Messages 1,679 Apr 17, 2022 / threads stripped #5 ask for a time sert. Next time the head is off have the hole Tigged and retapped.
