This doesn't seem like a good idea to me
You could be right, but how much does 54 cu/ft of shredded leaves weigh. May not be dragging around a lot of weight.
Darryl G
They can get pretty heavy if they're not dry, and there's likely to be grass in there as well. Dragging is way more strain on the machine than pulling something on wheels.
From my research it looks like that bag full could be 450-500 pounds
Scrubcadet10
Moderator
Staff member
I use the mule to haul the tarps of leaves out to the burn pile, if it's light enough i can throw them in the bed, but sometimes a bunch of wet leaves add up quick, that's when the 900 pound towing capacity comes into play ;)
Darryl G
According to this source you could be have over 1,000 pounds of leaves in that bag. Screenshot_20200914-115339.png
upupandaway
Well, build a little trailer for the bag to sit on then.
