Hammermechanicman
- Jan 10, 2020
- 52
- 3,512
Needed a new compression tester for bigger engines and auto engines. After a little research i picked up the Innova 3612. I specifically chose this one because it has the Schrader valve at tbe very end of the spark plug adapter. Like my small engine compression tester
Using both of these in the same 90cc chainsaw the readings are the same
Compare this with a cheap Ebay tester.
The cheap chineese tester has a crappy valve that is not at the very end of the spark plug adapter. If someone is looking to get a compression tester for small engines may want to pass on the cheap chineese ones.
