Tecumseh oh160
We will need the rest of the model number series. there should be another set of numbers on the tag with the model number that is normally 5-6 numbers followed by a letter. That is the specific engine within the overhead valve 16 hp engine.
blackchevy3de
I only found this craftsman Tecumseh 143.630012 16 hp
Russ2251
143.630012 cross references to Tecumseh OH160-170006.
Carb is #247 in parts explosion. Part# 631680 (Superseded to 632205C)
Edit:
Discontinued: NLA
Seems there is no replacement available anywhere.
Is old carb re-buildable?
