Tecumseh engine help
phayer
Hello everyone i am having trouble with my Tecumseh lawnmower. The engine starts and runs but surges and sometimes cuts out. Ive took the head off and the inside is full of carbon build up round the valves which i am going to clean, I tried cleaning the carburettor before but the engine still surges and runs high. Ive also noticed that the rods on the carburettor move as the engine surges.
Any help would be great.
Thanks James.
As I have posted a hundred times, you need to clean and rebuild the carb. You don't post the engine numbers, but I'm willing to guess you will need kit number 631021B. Follow this procedure and make sure you have your float level properly. Soon we will be starting to get mowers ready for the season here and I'll have to do this at least once a day through out the spring and summer.
Needle and seat replacement
Remove the carb, and then remove the float bowl. Check the float bowl jet (which is the bowl screw) and make sure the jets both horizontal and vertical are clean and open. Tip the carb upside down and remove the float pin and float with needle attached. Look in the float needle passage and you should see the red float seat at the bottom of the passage. This is where a #5 crotchet hook would come in handy as you need to remove this seat. If you have no hook, but compressed air, you can blow through the fuel inlet and try to pop the seat out. Put your thumb over the passage to prevent the seat from flying who knows where. No air or hook try bending a stiff paper clip to dig the seat out.
I would either give the carb a good 24 hour soaking or have it ultrasonically cleaned at this time.
With the seat out clean the passage way with carb cleaner. Now you must find a drill bit slightly smaller than the passage way, to be used to press in the new seat. Apply a very, very small amount of a very light lube to the new seat. 3-1 oil or lighter, to help seat it better. Carefully insert the new seat in the passage way with the rings on the seat down toward the carb body. Slowly and carefully force the seat down with the back end of the drill bit. Once it is seated, check to see that it did not flip and the rings are up. *Next check to make sure that the float does not have any liquid in it. *If it does, replace. *If everything looks correct, attach the new needle to the float and install with the float pin centered. It everything is correct, the float should seat level to the carb body, when looking at it upside down. If everything looks good reattach the float bowl, making sure that both the bowl gasket and the nut gasket seal properly. Reinstall on the engine and test unit. Remember to have patience and take your time. Good luck, but I don't think you'll need it.
PS: *On the side of some Tecumseh carbs you will find a plastic cover. *Under this cover will be an idle jet. *Remove it and check to see that the jet is open both horizontally and vertically. *You should be able to push the old float needle wire through the vertical opening.
phayer
Hello thank you for your reply very helpful, Ive looked on my carb and i cant find this plastic cover? I have took a picture if it helps Thanks.
That carb does not have a removable idle idle, so no plastic cover. The procedure I posted will work fine on the carb. Please post your engine numbers so I can give you the correct repair kit number.
YT125
Looks like you have the Dellorto carburetor
