Tecumseh carb leak.
Indyandy
So, I have this Craftsman snowblower with the Tecumseh engine. I cleaned the carb and got it running. Now a have a stream of fuel coming out the tiny hole above the adjustment screw. Why? What did I do to it?
We got to the equipment numbers. What you posted like telling us you have an American vehicle with an engine. 1000 models and engine combinations. We have no way of knowing what you actual in front you without you provide the needed info.
Indyandy
Engine# 143.694012 serial# 9250B, # on carb: 739 9J4
Craftsman snowblower# 536.918000
You have a float valve that not sealing. Most likely you blew the rubber seat out and lost it, or sprayed with carb cleaner and swelled it. Will need a new float needle and rubber seat.
Indyandy
Is the float adjusted so it sits level when turned upside down or should there be a slight downward tilt on this model?
It is adjusted with a slight downward tilt were you can slide a 11/64 drill bit between the float and the carb body at the gasket flange.
hlw49
631021 needle and seat kit or a hole in the float​
Indyandy
I replaced the needle and seat, no more leak.
Now the engine runs fine for about 1 minute and dies. Could the new needle be sticking in the seat?
Gord Baker
Be sure the Float moves freely now, is set level when inverted and that the fuel is turned on if there is a valve.
