PTmowerMech
- Apr 16, 2018
- 391
- 2,994
Earthquake digger, M# 9000 with a Tecumseh AV520.
If a two cycle comes in the shop with 100lbs or less, I don't normally mess with them. But this one is bigger. Looks almost like a 4cycle. It takes 24:1 mix. I'm only getting about 87lbs of compression. From what little I can see down in the spark plug hole, I don't see any scarring.
So my question is, is it worth the time and money repairing it with only 87lbs? Or can these still perform good with that much or a little less?
