TB360 Rattles when running until I pull on rope to tighten then stops
Swordfish80
  • / TB360 Rattles when running until I pull on rope to tighten then stops
Hi, I have a TB360 190CC. For the past couple years when I am cutting with it, it rattles like a chain a loose. Once I tighten the pull start assemble rope and hold the rattle disappears. I am wondering if I were to buy a hole new pull start assembly will this rattle disappear, or is there a chance it is something else. Pull start assembly is in good shape.
Thanks in advance.
Please post the engine numbers so we can see what recoil system you have.
Swordfish80
Sorry I am new not sure if this tells you. 3F72E00B-6E84-4CBA-A148-7884082A4C74.jpeg
Look on The metal housing which has the recoil attached for the engine numbers. The pic you posted is an EPA tag only.
Fish
Probably just needs the pull rope wound one loop tighter.
Fish
Or there could be some slop in the rivets that bolt the starter on to the housing.
Swordfish80
Ok I found the Engine Model is 121S 02 0068 F1
Swordfish80
Can this be done without disconnecting the rope and putting it back through the holes? Sorry I am trying to learn how to work on this stuff
Fish
Can you take a pic of the top of the engine? So we can see the starter better?
