I am swapping the crankshaft from blown 12000 series vertical engine to a lawn mower engine that was running and had very minimal leak-down.
After assembly I checked the crank endplay and its now way out of spec.
1)Crank I want in the donor's crank case and new gasket .027 play
2)Crank I want in the donor's crank case no gasket .010 play
Donor engine
before tear down .008
I put the crank, I do not want, back in the crank case with out the piston or cam installed to see if something changed and here is what I got
3)with new gasket .017
4)no gasket .001
What am I missing?
Does Briggs have shims for the 12000 series engines? I can't find them on my parts list.
Where do the shims go on this engine? The service manual says on the PTO side except on the 12000.
What is the thinnest gasket I can get?
Donor engine
4)no gasket .001
What am I missing?
