Two issues: Kohler SV720S is a pain to start. Won't turn over past the compression stroke. The compression release is messed up somehow. Valves are adjusted correctly, so I'm guessing now it's valve guides. Saw a video on how to tap those back in place and might give that a try this week. I'd rather try fixing this than buying a new head. This isn't as bad of an issue because I can at least get it started with a jump box.
The second issue is puzzling me. The carb isn't getting fuel. I can make it about 100 yards before it sputters for a few seconds and dies. There's very little fuel in the filter. This issue started when the motor was pointed down hill, now it won't run on flat ground. I've replaced the fuel lines, filter, fuel pump, and fuel cap. Still not getting fuel. I've cleaned the carb and checked the solenoid. All is clean with no obvious issues. Still no dice.
Is there something I'm missing?
