I am working on my father's John Deere L120. It started leaking oil around the oil pan gasket under the left side cylinder. The engine is out, and obviously the PTO clutch is off. My problem is how to get the smaller drive pulley off. There are no set screws. It appears this pulley is held on by the PTO clutch and a long bolt that goes up through them both in the shaft. However, I can't get it to budge with damaging the pulley. Any tips or tricks that someone might like to share?
BTW: It's soaking in PB Blaster now.
