Need help,
Have a Turf Tiger that is four years old with low hours that will not start. If you apply 12 volts to the small starter terminal it will start instantly and run all day. I have replaced the ignition switch, the pto switch and the relay. Checked all safety switches and they all trigger the relay. PTO function is normal and lights are OK. All fuses that I know about are fine. All replaced parts are OEM Scag. I have examined and wiggled all connections under the dash while having the key in the start position.
Anyone have any thoughts? I am stumped! Occasionally, when you try to start with the key, it will start and keep on starting for a few days then right back to no start.
Any and all suggestions would be greatly appreciated.
Thanks,
Knots a
Thanks,
Knots a
