use an old belt wrapped around it and anchored to something on the frame to keep the pulley and shaft from spinning. If you don't have an old belt use a rope strong enough it won't break. You run the belt or rope so it crosses over itself and tightens down on itself in the direction you want to turn the nut on the shaft.
