stops running when you release handbrake
DougBortle
I have an ex mark front runner when I release handbrake stops running I’ve checked the seat switch and that is working trying to figure out what could be wrong ,any suggestions
It is the sea switch or the wires between the seat switch & the brake switch.
Try turning the blades on & off while sitting on the seat, engine off.
You should hear the clutch going KLUNK if not then that confirms the seat switch / seat switch wiring is at fault .
Wiring includes relays were fitted but we can not check for them unless we have the full model & serial numbers from the tag under or behind the seat so we cal look up the correct wiring diagram.
