This hedge trimmer will stall when turned side ways, replaced carb and fuel lines. Bringing it back parallel to the ground if i'm lucky it will continue to cut. Thanks in advance for any help.
Pop off the starter top and take a peek. Look closely at the kill wires/circuit, see what it looks like.
On the ipl I only see 1 kill wire, I don't know it grounds to the block.
But one of the terminals may be loose and shorting things out when turned on its side.
