Stihl FS56 RC Carburetor Adjustment Assistance
Kennykenny
I have a Stihl FS56 RC trimmer. The unit starts up fine but will not idle when the throttle is let off, it dies pretty quickly. I am not clear on how to adjust the carb. in order to correct this. Assistance would be appreciated. Thank you.
Fish
Carburetor: all-position diaphragm carburetor with integral fuel pump.
Settings
High speed screw H (basic setting)
without limiter cap for servicing dealers:
1 1/2 turns open
with limiter cap for users:
3/4
turn counterclockwise (max. to stop)
Low speed screw L (Standard setting): 3/4 turn counterclockwise
Idle speed screw LA: As required, cutting tool must not turn
