Sthil. FS45C
Geochurchi
Hi All, having great difficulty installing and aftermarket recoil starter assembly, original was taken apart by my son and who knows where 1/2 the parts are, anyway the white plastic pawl with the little pin keeps snapping off, this is my second try, I wonder if a factory pawl would be a better choice, or am I doing something wrong when I assemble it?
Thanks
Fish
Yes, the aftermarket starter parts do not hold up very well, generally
Geochurchi
Hi, I believe thats what the C stands for, so yes, easy start.
C stands for Comfort feature. To have easy start it would need be C-E.
Fish
If you ever need to get parts, the fs38 is the same trimmer, and is still made.
Hammermechanicman
If it has the EZ start recoil be aware that you can't jerk it like a non EZ start. You need to pull slowly to load up the assembly till it turns the engine over. If you jerk on it hard it will break it. OEM or AM it doesn't matter.
Yep
And yet another owner misuse that people try to fob off as a warranty repair .
