stepping on the mower deck
john6412
i am getting older and it is getting harder to get on my t310 lawn tractor does anyone make a step to assist getting on without stepping on mower deck?
breagler
Afternoon John,
There are a few support handles on the market, just search for "Support bars for zero turn mowers" like the one below.
john6412
Those decks are pretty stout, put a 2" block under it, put it down on low on the block, climb on, raise the deck up, drive over the block.
thank you sir
tscovill
I usually put the deck to its lowest setting and step on it
bkeller500
If you lower the deck all the way down is it resting on the anti-scalp wheels? Wouldn't that be enough?
7394
Not necessarily, my anti-scalp wheels are still off the ground at lowest deck setting..
