SeniorCitizen
- Aug 28, 2010
- 123
- 2,108
Has anyone developed a convenient way to lube the sleeve bearing that supports the steering shaft near the pinion gear on a X350?
I just went through this on a 2140 Cub Cadet. The grease zerk ended up being on the opposite side of the tractor that the lubrication chart showed it. The zerk could only be seen with a mirror but wasn't that hard to get a flex hose grease gun on it.
Maybe yours is similar if it uses a zerk to lube the rack gear shaft?
Thanks for the suggestion but no such luck finding a zerk.
It took me 25(!) years to find mine. First grease it's had since it left the factory in 1994.
