steering link
golfer2716
hydro 165
link from steering wheel to front came loose where it attaches to the steering wheel.
it looks like a ball that fits snugly into a bushing. can it be repaired?
fastback
It depends on the what type of setup you have. On the older craftsmans the drag link had a ball and stud swedged in. I have made repairs by reinserting and cutting a washer to fit over the hole and welding it in place. This repair will last for years. However, if you have a drag link that has threaded ends you can buy replacement ball joints. I have seen some at Lowes in the lawnmower parts section. Hope this helps.
RobertBrown
Check your TSC store as well, Better yet use there online catalogue:thumbsup:
Briana
Hey there! WELCOME to LawnMowerForum! :biggrin:
I moved your thread to the Small Engine & Mower Repair Forum. You'll get a better response there. :thumbsup:
