Starting Issues Any Ideas?
youda97
I have a snapper with a Briggs and Stratton 6.75 HP mower. I am having starting issues. It does not seem to want to fire up. I bought a new spark plug today. I also removed the carb bowl And dumped out the fuel. Looked cleaned. Reinstalled fire right up no issues. Thought it was fixed. I mowed front lawn. Then refired up amd no issues. Shut it off again to dump bag. Then refired right up. Mowed some more. Shut down to empty bag. Now it won't refire. Any ideas? I also have had hard start issues in the past month or so.
EngineMan
Re-clean the carb and also check the kill switch.
Mike88se
Is there a fuel filter?
youda97
Where's the kill switch? In process of recleaning will follow up.
I am assuming you mean the kill switch is the handle???? I recleaned carb. Fire right up. Ran for 10 min. Shut it off. Tried to restart and did not start......
EngineMan
Post up the model numbers.
EngineMan
Item 935 is the kill switch its on the control bracket (carb)
