starter
clinton888
I have a briggs & stratton intek pro 10hp I want to put a electric start on it, Have to put a driffent flywheel on with ring gear
what flywheel i need model 205332 tyle 0130b1 code 100507yd
You may need to change the crankshaft too. But the flywheel is pn 794812. According to IPL the crankshaft does have different pn too. pn 794716
One note here, my Briggs price file is showing $0.00 for it which usually mean it is not available. So I check Power Distributors and they list it as no longer available.
Gord Baker
Not worth tearing down the engine. It should start with rope first pull.
Be sure you have fresh fuel and don't flood it. Electric Starters are over $300 Cdn.
Check with Donyboy.
