Starter magnet glue
PTmowerMech
Not sure if this is even worth the effort of a thread. But I was trying to find a starter to piece together, a couple of the ones I took apart, had loose magnets. Does anyone every glue their magnets back on? Or just junk them like I've been doing?
Romore
I have never had any luck trying to fix them.
AVB
Permatex 2 ton epoxy works. Just got to make you get the magnets in the right direction shimmed until cured. If installed wrong either the starter will not work at all or it turn backwards.
Probably someone has been beating the starters knocking the magnets loose when there was other problems causing a non-start condition. People used to do this on old automobile starters but the fields where held in place with screws, not glue.
PTmowerMech
Starters with just the two big magnets, you can't get them wrong, can you? I took one apart yesterday (off a Kohler) that had 4 magnets.
Tell me more about the shims. Are you talking about the distance between each magnet? Or spacing between the magnet & armature?
AVB
The magnets are polarized and yes you can install them wrong if you don't pay attention.
The shimming I mention is the magnet to magnet edge spacing. Without armature in place they will pull to the metal shell easily but they can also pull sideways and the factory spacing will disappear. Once installed and shimmed the epoxy should be allowed to cure overnight before assembly of the rest of the starter. You also should note the top and bottom spacing of these magnets as both should be installed the same depth.
tom3
I ran into a similar deal with the flywheel magnets. Pretty quick read here:
PTmowerMech
Since there was only two, I installed them just by guessing.
Don't laugh at me, OK? But I used Gorilla hot glue. After looking at the armature and seeing some of the copper wires broken, It's going in the scrap pile anyways. I saved the keeper, the gear and the washers. But the rest of it, is junk. Sooooo, I thought what the hell, just glue to see if I can get the spacing right.
What every they use at the factor, to attach these magnets, is tough stuff. I couldn't get it all off the casing. Seriously, I had a wire wheel, that fit pretty good inside the casing. And I went through to fully charged batteries on my cordless, before I stopped. And there was still some adhesive on it. (and see just how good this glue is. (Probably no better than the rest)
I have another decent starter with one lose magnet that I'll get serious with. It has 4 magnets, and
