ST160 Keeps throwing blade belt
Jonathan67
I put a new belt on and it spat it off after 20min in long grass I put it back on but spat it virtually straight away I'm not sure if its missing belt guides etc
Anyone got any ideas as to whats going on with it
Not without some photos
Loose spindle housing, broken housing , jambed blade big lump of debris stuck in a pulley.
Want another 20 or so ?
Jonathan67
I checked all that when it can off the first time
Is there any belt guides that prevent the belt from riding off?
Apart from the ones around the engine sprocket usually not for an electric PTO as it is tight all the time
Look up the IPL for your mower and check what is shown against what you have in front of you
Jonathan67
ok I'll have a look thanks
Ive been looking for a manual but cant find one ...do you have any pics
No
But lets make sure we are talking about the same mower
That is a Bolens Suburban Tractor ST 160 model 3016 from 1982 to 1984 .
1.Chinese belts in the wrong size or pitch.
2.Bad bearings in the idler pulleys.
3.Spindles going out.
4.Grass or a dead cat where it shouldn't be.
5.More grass up "in" there.
6.Deck not sitting level. Wrong deck for the mower??
Jonathan67
3.Spindals going out.
The mower deck came with the machine (48inch)
belts purchased from Sam's Bowlen parts
Bearings& spindles in good order and no grass on top of the deck
Does there have to be a certain amount of tension on the belt? If so how is it measured?
Tension yes. It's what keeps the belt on. Should have an idler pulley with a stout spring under there.
Bertsmobile1 will tell you exactly how many Newton kilo gram inch pounds there should be LOL. Joking of course. Bert is a VERY smart guy. (y) :)
Jonathan67
No
Hi mate Slomo told me you maybe able to tell me how much tension should be on the spring for the belt tensioner
42inch cut
Thanks, Jonathan
